Maintenance and Repair
Logical verification is used to determine if all emails located in MailStore are still complete and in their original state. For example, if a content file (.dat) was modified by hand, this will be censured by logical verification. Replace the number 1 with the actual number of the archive store to be verified:
VerifyStore --id=1
CompactMasterDatabase
